Anyone interested, please download this package http://s000.tinyupload.com/?file_id=284 ... 6365520933
Inside is folder with XnView 2.36, including custom xnview.ini and addon for testing named CrashTester in AddOn directory, and file to be loaded with this addon.
How to use: unpack, start xnview.exe from unpacked folder, open some picture in XnView Viewer mode, select menu Filter, choose CrashTester. Open included testing file, follow instructions on the screen, report results. These actions are harmless to original picture opened in Viewer.
What am I interested in, is how option AllFormats from section [Start] in xnview.ini (as well changeable through GUI
Options->General->tab Operations->checkbox "Display all image file types") influences ability of function LoadBitmap() to load included test file. My own tests on three different Windows platforms show that with AllFormats enabled LoadBitmap() returns value indicating success, and the opposite if AllFormats is disabled. The problem is, test file isn't picture at all, so it shouldn't be loaded ever.
You may test this function with your own xnview.ini, switching AllFormats on and off, and tell the difference.
I'm looking for volunteers because of strong "can't reproduce" reaction from developer of XnView.
Looking for volunteer guinea pig
Re: Looking for volunteer guinea pig
i've reproduced
Mixer
- Banned
Those who have bugs in release code but can't catch them in debug version might want to try tool like PVS-Studio.
