There is an issue that XnviewMP follows links when show files in subfolder is enabled.
Have a root folder with files
Add subfolder to root folder
Into subfolder put a link to root folder
Go to root folder enable show files in subfolder
Observe that all files are now doubled. XnviewMP displays the original files with their original path and the files with the path travelling through their link path. However the files with the link path are not accessible.
I don't think XnviewMP should display the files form linked folders. But if it shows them, it should not show them multiple times and they should be accessible..
Following links
