Remapping keyboard shortcuts
Octopuss
I changed the association for "/" key from "Fit image to window" to "Fit image to window, large only", but when I press the button and open the "auto image size" dropdown menu, the old "fit image to window" is selected instead. The key also shows next to that one.
Re: Remapping keyboard shortcuts
i can't reproduce
Octopuss
Let me show you a screenshot, it might explain better.
I suspect this is part of the reason why image size I keep setting gets randomly reset.
are you in Viewer shortcut?Octopuss wrote:Let me show you a screenshot, it might explain better.
Octopuss
Basically what I believe is happening is even though I remapped the "/" key from the default "Fit image to window" to "large only", the change is not acknowledged by the program, making it do the original action instead.
i shortcuts, you have 2 areas, Browser & viewer
Octopuss
Oh I can see what you mean. I had no idea there were two separate groups of shortcuts.
Maybe you could separate them in two tabs (inside the Shortcuts main tab)rather than in one long list then? I think it would make it a lot less confusing.
As for the Toolbar options, for consistency and a better interface...Octopuss wrote:I had no idea there were two separate groups of shortcuts.
Maybe you could separate them in two tabs (inside the Shortcuts main tab) rather than in one long list then? I think it would make it a lot less confusing.
... but possibly in both cases with titles Browser and Viewer, as these names are more commonly used than 'Browse mode' and 'View mode'?
