I don't like tab-brower...but I can't set the program...
Also will XnView be added the features that let user set the Layout & reset the Layout...cf.let the Previwe window move to under folder list or become float window?(Like ACDsee...)
Have to changes to XnView because The Image Viewers don't fully support UniCode also the Viewers are too big...
Let user set Layout?
Already possible---
• Indeed, you can choose the layout of the areas in the browser :
View Menu >> Layout
- What do you mean ? The tab of the browser can be hidden if only the browser is open (no file), see Options >> Tabs Tick the box : Hide tab-bar when only one window is openedI don't like tab-brower...but I can't set the program...
