Plugins and addons
jadO
Plugins and addons
Does XnviewMP support plugins and addons? Are there plans for such support?
Re: Plugins and addons
Yes: if you look in the xnviewmp folder of your installed or ZIP version, you'll see which plugins and addons are supported...jadO wrote:Does XnviewMP support plugins and addons?
But 64-bit software requires 64-bit plugins and addons, so some functions -- particularly support for rarer file formats -- are currently only available in XnView MP 32-bit
jadO
So customized plugins or addons are not possible? All information found is regarding classic version.cday wrote:Yes: if you look in the xnviewmp folder of your installed or ZIP version, you'll see which plugins and addons are supported...jadO wrote:Does XnviewMP support plugins and addons?![]()
