Hmmm, this isn't really a bug, but I don't know if you would call it an "improvement" - it has to do with the way things work, really.
Okay, so I have a handful of images that I run the batch-convertor upon.
I set them to resize and apply a new name.
So I run the convert process.
My beef is that the browser window does not populate the new images until I close the batch-convert dialogue.
I know the dialogue is modal, but (waaaaaa!) I want to see that it did it's job before I close out of the dialogue.
Maybe I want to go run the batch-converter again on those same files (and don't want to go through the parameters again), but I need to see that the results of the first round.
Batch Convert Dialogue
Brother Gabriel-Marie
Re: Batch Convert Dialogue
and if you open the batch convert as a tab?
What do you mean "open as a tab"? How do you do that? When I choose "Batch Convert" from Tools > Batch Convert, it opens a modal dialogue.
press SHIFT when you click on batch convert
- Forum Librarian
I had no ideaxnview wrote:press SHIFT when you click on batch convert
m.Th. ([url=http://newsgroup.xnview.com/viewtopic.php?p=122736#p122736]Newbie - Automating file conversion[/url]) wrote:There is a way, albeit not an obvious one.
1. Go to 'Tools'
2. Press {Shift}
3. With the {Shift} pressed, click on 'Batch Convert'
Now you have the Batch Convert engine not in a dialog but in a tab....and you can do other jobs while the "service" is running.
For a real GUI-wise fix together with other features see http://newsgroup.xnview.com/viewtopic.php?f=60&t=29204
I had no ideaXnTriq wrote:xnview wrote:press SHIFT when you click on batch convert
Only when Batch Convert is opened from the Browser, seemingly...
