image and thumbnail display problem
photodave
Post by photodave »
In viewing a folder of tif images, some images (and their thumbnails) are displayed with what appears to be histogram equalization.
When I display these images in mac Preview app or using Photoshop, they display normally.
Also if I export the image using Preview app without making changes the subsequent image is displayed correctly.
Do you know the reason for this?
Re: image and thumbnail display problem
could you send me a sample?
photodave
Post by photodave »
how to send you image?
can't seem to attach one here...
photodave wrote:how to send you image?
Files can be sent as follows:
1. By adding to a post as an attachment, 2MiB current forum limit, in a ZIP archive if the file format isn't permitted for attachments.
2. By uploading to a file hosting service and posting a link.
3. By sending as an email attachment to the email address below.
photodave
Post by photodave »
Here are the image examples...one displays correctly (roi.0204746100.tif) the other not (roi.0204753800.tif).
They both display fine in Preview and Photoshop, but not in xnviewmp
macbook pro
osx 10.8.5
xnview 0.79
Mixer
Banned
Post by Mixer »
Nice acidous colors. Screens made in XnView Classic 2.35. In other programs capable of opening .tif lower picture looks green-on-black like the one above. i know you here are discussing MP flaws, but MP users often post in Classic forum, so I thought, why not?
AWare Systems: AsTiffTagViewer
AsTiffTagViewer ([color=green]roi.0204746100.tif[/color]) wrote:
Tag Code        | Data Type | Count | Value
ImageWidth      |   Short   |   1   | 918
ImageLength     |   Short   |   1   | 294
BitsPerSample   |   Short   |   3   | 16, 16, 16
Compression     |   Short   |   1   | Uncompressed
Photometric     |   Short   |   1   | RGB
StripOffsets    |   Long    |   1   | 8
Orientation     |   Short   |   1   | TopLeft
SamplesPerPixel |   Short   |   1   | 3
RowsPerStrip    |   Short   |   1   | 294
StripByteCounts |   Long    |   1   | 1619352
MinSampleValue  |   Short   |   3   | 0, 0, 0
MaxSampleValue  |   Short   |   3   | 65535, 65535, 65535
PlanarConfig    |   Short   |   1   | Contig
SMinSampleValue |   Short   |   3   | 0, 0, 0
SMaxSampleValue |   Short   |   3   | 0, 0, 0
ImageWidth      |   Short   |   1   | 1020
ImageLength     |   Short   |   1   | 300
RowsPerStrip    |   Short   |   1   | 300
StripByteCounts |   Long    |   1   | 1836000
GnuWin: Tiff for Windows
tiffinfo.exe needs jpeg62.dll (Jpeg for Windows » Binaries) and zlib1.dll (Zlib for Windows » Binaries).
[color=green]tiffinfo -D roi.0204746100.tif[/color] wrote:
TIFF Directory at offset 0x18b5a0 (1619360)
  Image Width: 918 Image Length: 294
  Bits/Sample: 16
  Compression Scheme: None
  Photometric Interpretation: RGB color
  Orientation: row 0 top, col 0 lhs
  Samples/Pixel: 3
  Rows/Strip: 294
  Min Sample Value: 0
  Max Sample Value: 65535
  SMin Sample Value: 0
  SMax Sample Value: 0
  Planar Configuration: single image plane
[color=green]tiffinfo -D roi.0204753800.tif[/color] wrote:
TIFF Directory at offset 0x1c03e8 (1836008)
  Image Width: 1020 Image Length: 300
  Bits/Sample: 16
  Samples/Pixel: 3
  Rows/Strip: 300
  Min Sample Value: 0
ok, i found the problem, min/max sample value not correctly readed....
photodave
Post by photodave »
You mean XnviewMP does not read the min max values correctly?
If so, will it be fixed in the next version?
When is next version?
Thanks.
Mixer
Banned
Post by Mixer »
Windows users of XnView Classic already received repair in v2.36.
photodave
Post by photodave »
I'm using macbook pro w osx 10.8.5
xnviewmp version 0.79 x64 (Mar 22 2016)
looking forward to this fix.
