XnViewMP 0.79 doesn't preview audio/video files (0.76 is ok)
cadu
Post by cadu »
After updating from 0.76 to 0.79 XnViewMP stop previewing my audio/video files (all of them, even MP3!).
I removed 0.79 from my system (Win 10) and reinstalled 0.76. The preview is ok again (all video/audio playing smoothly), so I am supposing the issue is with 0.79 release.
Does anyone else is facing this problem? Any workaround for preview audio/video file with 0.79 release?
Thanks!
Cadux
Re: XnViewMP 0.79 doesn't preview audio/video files (0.76 is
0.79 use directx codec, do you have codec like klite?
m.Th.
Post by m.Th. »
hmmm.... it seems that I stumbled too on the same problem. In fact it is a general instability of the video subsystem. After a long wait, finally, the first 4-5 movies are played but after that the program freezes... Other times it works „better”. Definitely there are problems.
m. Th.
cadu
Post by cadu »
Thanks for answers!
I'm still having problems for preview audio/video files in v.0.79.
I uninstalled ffdshow (my previous codec pack) and installed klite (release 1210) in two different computers. I also tested XnView 0.79 portable and install versions (32bit and 64bit).
While v.0.76 could preview ALL video/audio from my sample files, 0.79 previewed just a couple of them.
In the following link I've selected a sample of video/audio files that weren't previewed by XnView in the two different computers I tried it: https://goo.gl/awtm3w (I also put there XnView .ini file for test purposes).
I would appreciate if you could try the video/audio files and let me know if the problem is from my computer/system, or if it is an XnView bug. Thanks.
cadu wrote:Thanks for answers!
on Windows 10?
cadu
Post by cadu »
On Windows 10 Pro x64, both computers.
