XnViewMP 0.79 x64 Open file very slow :(
Deetee
Post by Deetee »
Hi guys.
Im using Windows 8.1, 64 bits, XnViewMP 0.79
Whenever i open an image file (jpeg, tga, tiff etc), it took very long to open the file.
Previously (same version or slightly older versio, cant rmber), it was perfectly fine. I think 2-3 weeks ago, all of sudden it just load super slow.
Whenever i open an image file, it took approximately 7-8seconds to launch XnViewMP. Windows photo viewer open it in less than a second time.
I tried reinstall. Doesnt work.
I tried uninstall and reinstall. Doesnt work.
I tried uninstall, then delete all left over folders then reinstall... Doesnt work either....
Please help :(
Deetee
Re: XnViewMP 0.79 x64 Open file very slow :(
Post by Deetee »
no help at all? :(
Welcome to the forum, Deetee (-:
Did you delete xnview.ini (Help » About » General » INI filename) and the following registry entries?
  • HKEY_LOCAL_MACHINE\Software\XnViewMP
  • HKEY_CURRENT_USER\Software\XnView\XnViewMP
  • HKEY_CURRENT_USER\Software\Trolltech
youhave not that before with same version?
Deetee
Post by Deetee »
XnTriq wrote:Welcome to the forum, Deetee (-:
Hi XnTriq, Thanks for the reply... also thanks for the welcome :)
I still find xnview.ini inside my C:\Users\User\AppData\Roaming\XnViewMP
I am not good in regedit. Thus i am pretty sure i nvr touch anything in regedit.
but i did went to few regedit location that you listed there, most of them appear to be no value set on the default.
xnview wrote:youhave not that before with same version?
Hi XnView, I dont think i have such problem before with the same version. It just happen out of no where.
I used to thought my pc issue, until it last for several weeks that i was convinced it should not be pc issue.
Regardless... Today, magically... it works pretty fine.
Wouldnt say perfectly fine, but it is pretty alright now.
I dont know what is going on... and i didnt do a thing at all.
Previously it took 7-8 seconds just to launch xnviewMP.
now on local disk, it launch xnviewMP immediately and display very quick (probably 0.5seconds time).
but on network, it still launch xnviewMP immediately, but it will hang there for 2-3 seconds before i can click anything. (hang as in the image is shown on xnviewMP, but on top of that it is written as <empty> and the mouse is still on loading icon) (I rmber previously there is no delay at all)
Well... i guess it works fine for now. at least i don have to wait 7-8 seconds just for it to launch.
Thanks for both of your reply. sorry for the trouble as it just magically works alright now.
yuo open an image file from windows explorer, right?? If so i found a bug here
DeFi
Post by DeFi »
I'm also experiencing speed problems with the newer versions of XnViewMP (including 0.79). When opening an image file from the desktop right after booting the PC, XnViewMP takes 5 to 10 seconds to display it (system is on a SSD). Opening the file a second time is moderately faster. With my old XnView 2.32 it opens immediately under the same conditions. While experimenting to fix the problem, I deleted the ini-files and played with the thumbnail cache settings, but nothing seems to work. However I discovered a maybe related bug:
When I open an image file from the desktop or in explorer directly in viewer mode and start cycling the image files in the respective folder, XnViewMP will cycle through all files in the folder. This includes really all files (.lnk, .exe .obj ... etc.). The files XnViewMP can not render are displayed as blank. If I however switch XnViewMP to browser-view it first starts very slowly listing all files. After the listing is complete, it filters the files according to my settings, so only image files remain. If I now switch back to viewer-mode and start cycling the files, it only cycles the image files as intended. If XnViewMP is started in browser-view and an image file is opened from there, it also works as intended. I find it very strange, that the filter is applied after displaying a full list of all files instead of applying it before displaying files. I hope this description is useful in fixing the bug.
[edit] The bug may be the same as described here: http://newsgroup.xnview.com/viewtopic.php?f=62&t=32534 Thus, it seems to exist at minimum since XnViewMP 0.76.
Deetee
Post by Deetee »
xnview wrote:yuo open an image file from windows explorer, right?? If so i found a bug here
Yes bro. I open from window explorer.
Glad that you detected bug there. Hope it will be fix. :D
but for some unknown reason, now it seems to be alright.
DeFi wrote:Hi,
When i was suffering the problem, it doesnt make a different whether my that particular folder contains multiple files or single file.
As for older version of XnViewMP, i nvr experience such delay.
joro_abv
Post by joro_abv »
I can confirm I have this desktop issue for long time, since 0.75 and before and I'm almost sure also with the legacy XnView - it is happenning on the desktop exclusively and not always, but randomly.
Simply sometimes it takes 10-20 seconds to open a double-clicked desktop file in the viewer. If I open another file with double-click, even in a dekstop subfolder - it opens instantly. If I open the desktop file from the xnview file explorer - it also opens instantly. I had it on Win7 and now I have it on Win10 too.
xnview-support
Post by xnview-support »
Using XnView MP 0.86 on Windows 10 Pro.
I too am seeing extremely slow XnView startup times. This did not occur prior to XnView updates a few months ago, but ever since then the app can take 5-10 seconds to open to view a photo. This defeats the purpose of using the app.
I tried deleting xnview.ini (Help » About » General » INI filename) and the following registry entries:
but this did not help.
xnview-support wrote:Using XnView MP 0.86 on Windows 10 Pro.
if you start XnView MP and click on it to preview it or open the file in edit mode, same delay?
xnview-support
Thank you for the followup.
If XnView is open and the file is selected and opened from within the XnView interface, opening the file is instantaneous.
The delay only appears to occur when opening the file with XnView (via OS command) when XnView isn't already open.
Please note:
1. The system used is very fast and can open even large applications like Photoshop very quickly.
2. XnView used to open nearly instantaneously via OS commands to open photos. Only in recent updates does it suddenly take a long time for the application to open.
xnview-support wrote: The delay only appears to occur when opening the file with XnView (via OS command) when XnView isn't already open.
For example from windows explorer? The folder opened has a lot of files? which setting do you have in General>Mode when starting?
No problem with 0.84?
xnview-support
Yep!
It doesn't seem to matter. A few files or many files, the slowness is the same.
"Normal"
I'm not sure exactly which version was working quickly a few months ago; I didn't keep track of the version number.
Yep!
And if you start XnView in browser, no problem?
