Hello everyone.
I'm starting to use xnviewpro and I have some difficulty.
In particular with convert batch.
When I select the "as original" format I think that the program does not do any conversion. Unfortunately it's not what I get.
If I select "as original" the file is converted to png format and the size of the output file depends on "Preferences, View, Camera Raw, use .. embedded or half or full size".
This is an example of my conversion:
/Fotografia/TestXncView/2010_03_14/_K6T2799.CR2 1761x1174x24: loaded
/Desktop/Prova_serie_XnView/_K6T2799.CR2.png: saved
This way of converting it right?
Or I something wrong?
My aim is to select the raw files (canon cr2) that I chose (with categories) to develop in B&W and copy these files while keeping the directory structure.
That's because I'm used to store the files by date and I would keep this sort for the two categories (color and B&W).
Thanks in advance to those who want to give me information and explanations.
Orso.
PS
Work conditions: Imac 2008 and OS X el capitan
I do not speak English. I write with an automatic translator.
Be kind, answers with short sentences, like a manual of computers, would help me a lot to understand the answers.
Batch conversion doubts
- Forum Librarian
Re: Batch conversion doubts
Welcome to the forum, Orso.
If you activate Keep folder structure and Keep parent folder, …
- /Fotografia/TestXncView/2010_03_14/_K6T2799.CR2
- /Fotografia/TestXncView/2010_03_14/_K6T2799.CR2.png
- XnView Forums
- Adobe Forums
- Photography-on-the.net Forums
- Slickdeals Forums
Orso
Hello XnTriq and thanks for your quick and comprehensive answer and also for the links you provided me.XnTriq wrote: Although XnView MP can read CR2 files, it doesn't have write support for this (proprietary) format.
That's a lot of material to study!
- Forum Librarian
Please let us know once you've found a solution (-:
Orso
Hello XnTriq indeed I have found two possible solutions.XnTriq wrote:Please let us know once you've found a solution (-:
First solution:
just add an entry to the batch conversion menu.
The program has already prepared the list of files to be passed to convertion engine and the source and destination directories.
* Pseudo-code *
Instead of "for in $list files; do convert $list $list.png endo"
simply just replace convert "format as" with a system call (system (copy (or move as user wish) $list /destinationdir/$list).
This first solution is very convenient for users, the work is done by the programmer excellent XnViewPro software.
Second solution:
Pending the first solution if there ever will be I have not been watching the water passing under bridges. Who acts as one make for three.
I have made a tiny little script that solves the problem.
WARNING! This script works with OSX bash and is deliberately incomplete to avoid problems for those unfamiliar.
Furthermore the script is crude, there is no error checking, everything is in the hands of the user.
I must say that the script is simple, those who know how to work with bash will not have problems to adapt it to their needs.
cat test_export-list.txt | awk '{print("cp "$1" "$1)}' | sed 's/Fotografia/Blackwhite/2'in this way we get the following code:
cp /Volumes/Public/Fotografia/TestXncView/2010_03_14/_K6T2996.CR2 /Volumes/Public/Blackwhite/TestXncView/2010_03_14/_K6T2996.CR2
cp /Volumes/Public/Fotografia/TestXncView/2010_03_14/_K6T3000.CR2 /Volumes/Public/blackwhite/TestXncView/2010_03_14/_K6T3000.CR2
cp /Volumes/Public/Fotografia/TestXncView/2010_04_15/_K6T3291.CR2 /Volumes/Public/blackwhite/TestXncView/2010_04_15/_K6T3291.CR2
... and so on.
- Forum Librarian
Thanks for reporting back and sharing your solution(s), Orso
