Steps to reproduce:
2. LMB+hold (may be setting specific) to select a rectangle
3. Press Ctrl+X
What should have happened:
Rectangle should be replaced with background color, e.g. white
What happens:
Nothing
Workaround:
4. After nothing happens in step 3, go into the menu Edit->Cut and press that
5. Rectangle is now replaced like it should have been
6. Select another rectangle
7. Press Ctrl+X => Now the shortcut works suddenly!!
0.79 Ctrl+X not working directly after start
Re: 0.79 Ctrl+X not working directly after start
See Issue 852 for current status and details.
Works fine for me in XnView MP 0.80 and 0.84.
Closed (Please post here in case the problem should still occur).
