As showed in a snapshot of my computer running Win 10, XnViewMP 0.79 ins't listed among apps that can be set default photo viewer: http://i.imgur.com/A7qDDKc.png
For instance, FastStone appears in this list. I tried to reinstall XnViewMP 0.79, but it keeps not being listed.
How to set XnViewMP as default photo viewer? Is there any workaround to make it appear in the default photo viewer list?
Thanks,
Cadux
How to set XnViewMP as default photo viewer (Win 10)?
cadu
Re: How to set XnViewMP as default photo viewer (Win 10)?
do you have used the setup package?
cadu
I'm running Windows 10 64bit.
I used XnViewMP 0.79 Setup Win 64bit.
Tried to reinstall XnViewMP, but it is still out of the default photo viewer list.
If you need more info, just let me know.
do you know registry?
cadu
Yes.
Just let me know what to handle in registry.
Cheers
Cheers
you need to search XnViewMP>Capabilities, and remove this key, and reinstall it
