I'm trying out XnView for converting Nikon NEF RAW files, prior to post processing with GIMP.
Everything seems to work fine, but I'm not certain about what I see when I load a NEF image. Am I seeing (and able to work on) the actual RAW image, or am I looking at the embedded JPG? If it's the JPG I'm seeing, then how can I get to the RAW image for processing?
If anyone can clarify those points, I'd be grateful.
Nikon NEF files - What am I seeing?
lincal
Re: Nikon NEF files - What am I seeing?
What you see is the embedded JPEG.
There is no way to see the RAW, as far as it is not a view-able bitmap file unless it is converted. This is the reason why there are RAW converters, and each of them give it's own conversion with the implemented rules. Furthermore, when you open the RAW file in Gimp, you probably don't see the same image than in XnViewMP, because the embedded JPEG is the RAW file converted by the camera itself.
Gewitty
Thanks for clarifying that, it's what I suspected.
XnView is still a pretty awesome and very useful app, as it enables the extraction and editing of the hi-res JPGs embedded in the RAW files. I already use RawTherapee and GIMP for managing RAW files, so XnView is another great addition to the toolbox.
toyotadesigner
You can use Fast Raw Viewer (OS X) to preview Raw files at blazing speed.
hobbyists discuss new camera features
photographers discuss new software
masters discuss light
Gewitty
Unfortunately, Fast Raw Viewer only works on OS X and Windows, I'm a dedicated Linux user for many years now, so only tend to use Open Source apps.
toyotadesigner
My apologies, I didn't know you are using Linux.
For Linux you can use DCRaw. Half size, JPEG output. Pretty fast on a modern machine.
lincal
If it's just a viewer, I do not see it as a worthy solution. Actually, it has it's own RAW converter, witch will no be the same than the RAW converter you will use for the development, that you will need anyway to get the final, usable, photo. In my experience, based on the use of several different RAW converters, the argument of seeing the real histogram is wrong, because it will also be calculated after RAW conversion and, trust me, RAW converters are not equal in this domain, especially if you have under or over-exposed photos!toyotadesigner wrote:You can use Fast Raw Viewer (OS X) to preview Raw files at blazing speed.
At the end of the day, the only efficient method is to open the RAW files in your RAW converter
- Forum Librarian
FYI:
XnViewMP ([color=green][u]H[/u]elp[/color] » [color=green]About[/color] » [color=green]Credits[/color]) wrote:RAW function is based on dcraw from Dave Coffin - http://www.cybercom.net/~dcoffin/dcraw/
m.Th. ([url=http://newsgroup.xnview.com/viewtopic.php?p=112634#p112634]RAW conversion in Viewer[/url]) wrote:eet wrote:Great software and super fast - thanks!
Frequently use image viewers to make quick corrections and conversion of RAW files that do not warrant editing in a
more complete software - But, I am unable to figure out how to disable the automatic image correction applied to the RAW files when I enter the viewer to do editing.. I am opening an NEF file and it is automatically converted to RGB/8bit as well and the color balance and exposure are being automatically 'enhanced' for me.
Don't want that.
Please let me know if there are some options available.
(Using Linux Mint 14 KDE, 64bit)
Do you know that the thumbnail of the RAW file (the one which you see in the XnView's thumbnails, previews etc.) is different from the actual RAW image?
This isn't a problem with the XnView and/or dcraw (the raw engine behind XnViewMP) but with the way in which .NEF thumbnails are built by your camera which isn't an accurate representation of the RAW data. See here:
http://forums.adobe.com/message/4990383
...but if you want to work only with RAW embedded thumbnails (in fact, I do) go to Tools | Settings | View and choose for 'Camera RAW' setting the 'Embedded preview'
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=116403#p116403]RAW support[/url]) wrote:Yes, right. The RAW will be loaded and not embedded jpeggreenkoopa wrote: Back when I was working only with jpegs, I unchecked Settings>Thumbnail>Use embedded thumbnail to avoid the black horizontal bars. I think this now has the effect of preventing the raw file's preview image from being used to generate the thumbnail.
It's only for viewing not thumbnailAs for Settings>View>Camera RAW. Setting this to embedded preview does't help. It behaves just like it was set to half size. And the half or full size raw image isn't the same as the output from ImageMagick or the Sony RAW Driver. How is it generated?
