Get background transparency
whosronni
I'm very new to this software and I'm trying to crop my images into a circle. Is there a way to make the white background transparent? The file attached is an example. Thanks for the help.
- Forum Librarian
Re: Get background transparency
Welcome to the forum, whosronni.
If all of your images are cropped to the same dimensions (017.jpg = 102×102 pixels), you could create a 102×102 grayscale mask and use that as alpha channel:
- Actions » Add action » Image » Add mask: mask.png (Use mask as alpha)
whosronni
Awesome, thank you for the help XnTriq. Worked like a charm.
