Auto expand tree
ElderP
Auto expand tree
Is there a way to auto expand folders in the tree window similar to the behavior in XnView classic when checking the option "Single click to expand folder tree"?
Re: Auto expand tree
no currently no way
ElderP
Thanks for the reply.
Any plans to add this in the future?
Also, XnViewMP allows drag and dropping from the file tree to other programs on the desktop. Is there a way to do this in XnView Classic?
I use your program to view pictures and would like to send the current directory to a file renaming program
