since the last update I experienced the following behaviour using the feature Tools-> Import and sort.
I set the the source folder and the target folder, the execution hangs at 24% of completion.
Is there anything I'm doing wrong in setting the parameters?
Thanks a lot and have a nice day!!
Best Regards,
Marc
Import and sort hangs
marchausmann
Re: Import and sort hangs
yes a known issue
Sander
Really sorry to read this. Hope it can be resolved in the next version.
@Pierre: Was this known issue resolved? What is the issue number?xnview wrote:yes a known issue
yes resolvedhelmut wrote:@Pierre: Was this known issue resolved? What is the issue number?xnview wrote:yes a known issue
This problem is supposed to be resolved in v0.84. Could you please try and check, marchausmann?
