0.76: MacOS: Cut menu item grayed out?
theamap123
Post by theamap123 »
I get this bug today, suddlenly the "Cut" menu item is grayed out. I can't cut and paste images between folders. Please help me to fix this.
Thank you all.
Re: Cut menu item grayed out?
even by restarting XnViewMP?
theamap123
Yes I restarted everything, OS & XnView. It seems like occured when I upgraded to new version 0.79.
theamap123
I have to back to 0.7.6 and it works, you should look into the new versions.
Cheers.
theamap123 wrote:I have to back to 0.7.6 and it works, you should look into the new versions.
i don't understand, cut is not greyed for me
