I'm trying to use EXR with nconvert in centos7.
Do I need to install a plug from this support or Is there a particular env to setup to hanlde exr file (and link to openexr lib files) ?
cheers,
Linux EXR support
Re: Linux EXR support
yes you need the plugin Iimlmf.so from XnViewMP package
