UNC not working any longer
stussy
Hello, I dont know what happened. Since the last update the "expand UNC folder tree" is not working any longer ( windows 7 ). I didn't change my xnview.ini file? the variable ExpandUNC=1 is still in the ini file. Could it be that the problem is not xnview but our server?
Re: UNC not working any longer
strange, i've tried and it works...
stussy
Hi Pierre, thank you, then it is our server that is causing this problem. We had a server crash last week and the IT changed something. I don't know what exactly they changed, but they will fix it. So xnview is working fine
