Batch renaming quits at start
MAD3000
Post by MAD3000 »
i'm trying to rename my pictures using the batch renaming function.
I select all pictures, then push F2 to switch to the batch rename function.
Then i activate the first checkbox and use the command {EXIF:Date Taken [Y-m-d_H-M-S]}
In the preview in the lower site of the window shows the correct name after the rename process.
But when i click OK, the renaming process quits without renaming and a message box tells me that an error occured and the pictures were not renamed.
What am i doing wrong? :(
Greetings
MAD3000
Re: Batch renaming quits at start
if you try with only 2 picture files?
MAD3000
Post by MAD3000 »
Just tried it, but still the same error message.
EDIT: Tried another way: Copied some pictures in the pictures directory of Win10. Renaming works.
Then copied the whole files i want to rename in the pictures directory of Win10. Renaiming doesen't work :(
Even the files i copied in the first try which worked were not renameable.
Mixer
Banned
Post by Mixer »
Is it custom error message displayed by XnView or general error message displayed by Windows? And what exactly this message is saying?
MAD3000
Post by MAD3000 »
The error message is thrown by XNViewMP: An error occurred, files can't be renamed.
MAD3000 wrote:The error message is thrown by XNViewMP: An error occurred, files can't be renamed.
how many files do you have?
MAD3000
Post by MAD3000 »
xnview wrote:how many files do you have?
1419 files
1419 files
is it possible to have an archive of the files?
MAD3000
Post by MAD3000 »
Sorry, but that would be over 1GB of pictures even in an archive and there are many personal pictures that i don't want to share with someone i don't know.
I helped myself with another renaming programm.
It would be very helpfull, if the error message would be more "speaking".
and how are named your files?
MAD3000
Post by MAD3000 »
You mean which program i used to rename the files?
MAD3000 wrote:You mean which program i used to rename the files?
no which names have your files?
MAD3000
Post by MAD3000 »
2012-11-28-16h02m10.jpg for example.
I got to say, that the other program didn't renamed 4 files. But all other files were renamed.
This seems to be a common problem:
OpenedFilesView helps you to find the process locking your files.
MAD3000 wrote:2012-11-28-16h02m10.jpg for example.
your 4 files are like "2012-11-28-16h02m10.jpg"?
