Hi. For some reason PNGs downloaded from http://deadendthrills.com/ are not shown in thу browser. I see that they are shown when I first open the folder and program scans it, but then they dosappear and are not shown anymore in the browser. Though I can successfully open them in the viewer and if I save same file with a diiferent name it's then shown in a browser. Have no idea what's wrong with the original. I will not attach an example, as they are pretty large in size.
It is not reproducible in XNViewMP - it shows them all.
Some PNGs are not shown in XNView Classic
-= Mancubus =-
Mixer
- Banned
Re: Some PNGs are not shown in XNView Classic
Please tell if checkbox in your Options->section Browser, subsection File List->tab Misc.->"Recognize only by extension" is enabled or disabled. I have saved one picture from this website, and, despite having extension .png, this is JPEG TrueColor v1.1 as detected by XnView. When I select "Recognize only by extension", leave and then re-enter directory containing this file, it's not present in the list (I use filtering by Images mode for Browser). With deselected "Recognize only by extension" this file appears fine.
-= Mancubus =-
Hi, yes, inedeed this option was On, and it seems it's On by default, I don't remember changing this.
Thanks, it solves the issue!
