[v0.79]: Full screen toggle [F11] logic
deus-ex
Post by deus-ex »
The switching sheme of the shortcut [F11] for toggling "full screen mode" behaves differently compared to XnView. In XnViewMP [F11] switches between the browser and full screen, and only when in the Viewer [F11] switches between Viewer and full screen. In classic XnView [F11] also switches between browser and full screen, but when in full screen or viewer, [F11] switches just between these two.
Additional [F11] issue in XnViewMP: When the browser list either is completely empty or when a subfolder is highlighted, pressing [F11] toggles an all black full screen which cannot be exited with [F11] anymore, instead one needs to press [ESC] or [Alt+F4].
Re: [v0.79]: Full screen toggle [F11] logic
deus-ex wrote:The switching sheme of the shortcut [F11] for toggling "full screen mode" behaves differently compared to XnView. In XnViewMP [F11] switches between the browser and full screen, and only when in the Viewer [F11] switches between Viewer and full screen. In classic XnView [F11] also switches between browser and full screen, but when in full screen or viewer, [F11] switches just between these two.
sorry but i don't understand. when F11 doesn't work?
right
deus-ex
Post by deus-ex »
Hello Pierre,
thank you for reviewing my post. Please find below a comparison of XnView Classic/XnView MP F11 behaviour.
1.
XnView Classic: In browser view, with an image highlighted in the file window, pressing F11 cycles between browser and full screen view of the highlighted image.
XnView MP      : same
2.
XnView Classic: Viewing an image in viewer mode, pressing F11 cycles between full screen view and viewer mode.
XnView MP      : same
3.
XnView Classic: Viewing an image in fullscreen mode, pressing F11 cycles between viewer mode and full screen view.
XnView MP      : Viewing an image in fullscreen mode, pressing F11 cycles between browser mode and full screen view.
For No. 3, I would expect (and prefer) XnView MP to behave just like XnView Classic. If the different F11 behaviour is by design, I'd welcome an option to enable XnView Classic F11 mode.
deus-ex wrote: 3.
I have the same behavior (cycle beween viewer & fullscreen mode)
By viewing in fullscreen, you means start XnViewMP with a file from windows explorer?
deus-ex
Post by deus-ex »
xnview wrote:By viewing in fullscreen, you means start XnViewMP with a file from windows explorer?
No, I mean entering fullscreen view from the browser mode.
i start XnViewMP, open a file from browser -> view mode, press F11 -> fullscreen, press F11 -> view normal, you have not that?
deus-ex
Post by deus-ex »
No, I don't have that, because I configured the interface switching modes differently to the default settings:
Use double click to switch between: Browser -> Fullscreen -> Viewer
Use middle click to switch between: Do nothing
Use ENTER to switch between: Browser -> Fullscreen -> Viewer
Might that be the root cause for the different behaviour? That would be strange because I use the same interface switching setup in XnView Classic.
how do you open the file??
always correct, please send me your xnview.ini?
deus-ex
Post by deus-ex »
xnview wrote:how do you open the file??
I open the file from XnView MP's browser pane with the ENTER key.
I attached my ini-file to a different post regarding the Refresh (F5) issue: http://newsgroup.xnview.com/viewtopic.p ... 49#p132749
ok, so with ENTER you are in fullscreen but always in browser mode, a view tab is not opened.
I need to add 'Browser>Fullscreen (view mode)>Viewer'
