first use - make db
leandromarino
first use - make db
Post by leandromarino »
Hi all,
I'm using the for the first time the XnView. I have an folder with several images (+60k) all this images are in folders and subfolder. To get all thumbs and infos do I have to enter in each folder? Is there any fastest way for doing such thing?
Tks in advance.
Re: first use - make db
Welcome to the forum, leandromarino (-:
If you click on a folder in the treeview with the right mouse button, you'll find the command Show all files (recursive) in the context menu.
