Noticed that large thumbnails are blurred, vainly tried to find settings that will sharpen the thumbnails.
Q: where can I find it?
Meanwhile, I went into Settings->Browser->Catalog->db settings
Noticed a LOT, I mean a LOT of folders in the 'cached directory'.
[Delete All] button (at the bottom) didn't work. I could delete some cached folders of non-existing paths (paths to disconnected external USB drives)
There are sooo many folders still left under 'Cached Directory' - I would not know whether or not they all exist.
Anyway I clicked on 'Rebuild thumbnails' and it will take (quite) a while to do so.
Not sure whether that is the solution though.
attachment shows a preview by Directory Opus (left) and XnViewMP latest version, right.
http://www.xnview.com/mantisbt/view.php?id=56
http://newsgroup.xnview.com/viewtopic.php?f=60&t=28595
Blurred thumbnails - where is sharpening?
mrwul
Re: Blurred thumbnails - where is sharpening?
please check Settings>Catalog>WidthxHeight
mrwul
? Okay, but then what?xnview wrote:please check Settings>Catalog>WidthxHeight
A Compression setting that results in sharper thumbnails: Lossless (ZIP) or a higher quality Lossy option ??mrwul wrote:? Okay, but then what?xnview wrote:please check Settings>Catalog>WidthxHeight
mrwul
It is set to 'None
set to lossless zip and also tried high quality jpeg
does not make any difference
(closed and relaunched XnViewMP in between)
And you clicked on Rebuild thumbnails ?mrwul wrote:It is set to 'None
Ah, you asked originally about sharpening, and I see that in XnView MP that option can be found in Tools > Options > Browser > Thumbnails -- Misc tab
mrwul
Yes, I clicked rebuild.cday wrote:And you clicked on Rebuild thumbnails ?mrwul wrote:It is set to 'None
As for sharpen, that has been 'set'
And you still have blurred thumbnails?
mrwul
Yes, regretfully so. I can submit another examples, but they are 'big' and I am not sure Pierre agrees to that.
Does selecting Sharpening have a visible effect, could it be that it isn't operaring correctly?
The current forum upload limit is 2MiB, but you could upload larger files to a file hosting service and provide a link, or if necessary send an example to Pierre as an email attachment at the xnview contact address on the home page...
Is the problem possibly confined to large images, which might require a different sharpening setting??mrwul wrote:I can submit another examples, but they are 'big' and I am not sure Pierre agrees to that.
mrwul
mrwul
That aside, I again started 'rebuild thumbnails' and I noticed that some thumbnails are sharp now.
Rebuilding takes quite some time and it is rebuilding thumbnails (at least it looks that way) of a lot of folders, outside the 'Base path of your pictures'
(settings-browser-catalog)
I mean: I have X:\JPG there (example)
in cached directory it showes e.g. X:\Photos D:\Downloads C:\Users etc.
bump
bump
