To remember popup size
theprez
Post by theprez »
Hello, started to use this nice program.
I have a little problem, I use a lot the "Move To" and "Copy To" features, when the popup open is, in my very high definition screen, quite small with small parts of the folders tree visible. Every time I have to enlarge the popup using the border or the corner. The problem is that the program does not remember the last size set... every time is back to the small size.
Any suggestion?
Thanks in advance,
tp
