Hello:
I am trying to open an .eps file from within Xnview, and get the error message "Ghostscript is not found on your system. ...". However, I downloaded and installed gs919w64.exe just about an hour ago, and restarted the computer. And gs is installed here: C:\Program Files\gsgs9.19\
bin\gsdll64 (among others)
doc
examples
lib
libpng
openjpeg
zlib
uninstgs.exe
So, I wonder why Xnview cannot find Ghostscript? Any ideas?
Thanks/Hans L
Ghostscript is not found ...
Re: Ghostscript is not found ...
If you are using XnView Classic it is 32-bit software so you need to install GS 32-bit even on a 64-bit operating system...
Hints in FAQ "How to display vector formats like PDF, AI,...? GhostScript!" might be also helpful.
Hans L
Looks like I did not respond to this. Doing what you said, all is now working well.
Regards,
Hans L
Regards,
Hans L
