[Request] Please add LockZoomFlag behavior to XNViewMP
rfrank
Post by rfrank »
I have my XNviewMP configured to "Auto Image Size - Fit image to Window, Large Only".
However I recently began working with very large images that needs Zooming for reading.
If I Lock the Zoom... it stays with the Zoom locked even if i close and reopen the program.
XNView has a command that you input in the xnview.ini file "LockZoomFlag" that you can enable so the program keeps the zoom behavior or resets it after closing the file/program
Could you please add it to xnviewmp as well Pierre?
Thanks in advance for your answer.
Re: [Request] Please add LockZoomFlag behavior to XNViewMP
See Issue 889 for details.
