Since last update, my videos started to play automatically.
I checked the options, and everything is unchecked.
I also checked the .ini file, and everything is on "false".
But as you can see in this screenshot, the video starts playing on its own when it's selected.
And it's really bugging me, because I'm used to open my videos with another player. Now, I have to pause it in XnView, and then launch it elsewhere.
Hope you can help me.
Greg
Edit: I found this post which is almost the same problem, but never got a solution in the end...
http://newsgroup.xnview.com/viewtopic.p ... 28&start=0
