Loss of EXIF data
herb
Loss of EXIF data
Post by herb »
I work with XnViewXP 0.80 and have a *.jpg image (out of camera) with many EXIF metadata.
Please see attached screenshots 1 and 2.
My settings Tools -> Settings -> Browser -> Misc are all unchecked:
- "Change EXIF orientation ONLY" is unchecked and
- "Use lossless roation (if possible)" is also unchecked.
I performed a rotation -90 degree with toolbar command cmd_rotate270 (not containing l).
The result was a rotated image, BUT all/many EXIF metadata got lost.
Please see screenshots 3 and 4.
I hope you can reproduce this error with the image I sent to you for topic: Problem with exif orientation.
Is this an error or what did I wrong?
Best regards
Herb
Rotate-90.zip
(132.36 KiB) Downloaded 259 times
Re: Loss of EXIF data
Did you save the file using Save as... or Export...?
What is your configuration in File (view mode) » Format settings... » Write » JPEG?
herb
Post by herb »
Hello XnTriq,
I did NOT "save" the file nor did I an "export".
As said, I was in Browser-Mode, had selected one thumbnail and performed a cmd_rotate270 (without l) by clicking the toolbar icon.
My settings Tools -> Settings -> Browser -> Misc are both unchecked:
As far as I know there are no further settings that are to be taken into account for rotate commands.
My format settings (of view-mode) for JPG are 4 times Keep EXIF/IPTC/XMP and Icc_Profile.
Best regards
Herb
Bug confirmed :bugconfirmed:
See Issue 888 for details.
herb
Post by herb »
Hello Pierre, hello Helmut,
I have retested this report and it is corrected in version 0.84.
Best regards
Herb
herb wrote:I have retested this report and it is corrected in version 0.84.
Great - thank you for retrying and reporting, herb!
