Pierre,
using 0.80 (Linux 32-bit) there's a new bug regarding filenames in file selection dialogs.
Take any folder which has JPEG images using both .JPG and .jpg extensions (upper and lower case). Take any file and "Save As".
Select the folder and select the JPG file filter.
Only images having lower-case extensions are listed. Images having upper-case extensions are not.
Regards
Dietmar
0.80 Linux: Name filter in file selection dialog
dietmar
