CPU at 100% version 0.80
andrei030
Post by andrei030 »
Hi, I work with Pentax raw photos, dng format, yesterday I copied the photos from the camera and I can't view the photos with the last version of XnViewMP (0.80), the CPU (i5 4590) goes to 100% and I'm only able to see the photo I just opened, when I go to the next photo it "freezes", even when I close the program it still working at 100% I eventually have to kill it from Task Manager. I've never had that problem before, so I installed an older version (0,76) and now it seems to work perfect, lightning fast, it just loads every photo instantly.
Edit: I've recently reinstalled xnView and problem seems to be solved. I wasn't remembering why I stopped using this awesome software but remembered posting in the forums.
Re: CPU at 100% version 0.80
same problem with 0.79?
andrei030
Post by andrei030 »
xnview wrote:same problem with 0.79?
Sorry, I don't remember if I've skipped any version, that's why I downloaded an older one to be sure that it works. I will uninstall 0.76 and install 0.79, then I will update with news.
Edit: 0.79 installed and works fine.
But now 0.80 also works fine again, maybe uninstalling and installing it again solved the problem? but how? the settings weren't deleted when I uninstalled, I'm using the same settings since the first time I installed it.
I will keep the last version installed and come back with news.
PS: I cannot delete files in 0.80 but I think is a know issue.
andrei030
Post by andrei030 »
0.81 going slow again. I definitely go back to 0.78 or so (never had any problem) and disable update reminder.
andrei030 wrote:0.81 going slow again. I definitely go back to 0.78 or so (never had any problem) and disable update reminder.
It's not normal, do you have tried to rename your xnview.ini?
Erixx haxx
Post by Erixx haxx »
Do you maybe have the same problem as in this post:
http://newsgroup.xnview.com/viewtopic.php?f=82&t=33363
