Switching between tree pane and browser pane
deus-ex
Post by deus-ex »
XnView Classic
My visual setup of XnView Classic looks like this (preview pane permanentely disabled): http://i.imgur.com/Tt1Qpss.png
This way I'm able to switch back and force just between the tree pane and browser pane with the TAB key.
XnView MP
I made a similar visual setup for XnView MP: http://i.imgur.com/6giqp1X.png
Yet I'm unable to switch just between the tree pane and browser pane with the TAB key. XnView MP cycles between the browser pane, the tree pane and a third unvisible item. I cannot make out what this third unvisible item might be and how to disable it. Does anyone have an idea/clue?
Re: Switching between tree pane and browser pane
right, it's a bug of QT API
deus-ex
Post by deus-ex »
Which means it is out of your control, i.e. you can't fix it yourself, right?
deus-ex wrote:Which means it is out of your control, i.e. you can't fix it yourself, right?
yes i have contacted the support
