"Add Text" can't display some Traditional Chinese text
Wang
Post by Wang »
Add Text to Image.
Image->Add Text
e.g.,
If I add text "生日快樂" and press "OK", doesn't work and shows nothing.
If I add text "生日快樂" with a dot(.), exclamation(!), etc. and press "OK", it shows and adds text to the Image.
Thanks.
Re: "Add Text" can't display some Traditional Chinese text
XnView Classic doesn't support Unicode chararacters so you need to use XnView MP.
I don't see an add text function in the Viewer menus for XnView MP 0.79 so possibly it hasn't been added yet, but the function is available in Tools > Batch convert... which can also be used on single images...
