elfroggio
Posts: 83 Joined: Sat May 30, 2015 9:13 pm
Post
by elfroggio » Sat Jul 02, 2016 8:49 pm
I just upgraded from an older xnviewmp (0.76) to 0.81. One of the item in the changelog is:
080: sidecar support
Is there any documentation on what/how to use it?
I opened a directory with all the images having a sidecar: 123.cr2 and 123.cr2.xmp and I do not see the sidecar data in xnviewmp when I view the image ie: keywords,...
Thanks
Syv
Posts: 6572 Joined: Sun Sep 25, 2005 3:00 am
Post
by XnTriq » Sat Jul 02, 2016 9:16 pm
What are your settings in
T ools »
Settings... »
Metadata »
IPTC & XMP »
Keywords ?
Posts: 48170 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Sun Jul 03, 2016 7:21 am
If it doesn't work, please send me one file with sidecar?
elfroggio
Post
by elfroggio » Sun Jul 03, 2016 7:16 pm
XnTriq wrote: What are your settings in
T ools »
Settings... »
Metadata »
IPTC & XMP »
Keywords ?
Is this correct?
http://i.imgur.com/HZDwSZF.png
Thanks
Syv
elfroggio
Post
by elfroggio » Sun Jul 03, 2016 7:18 pm
xnview wrote: If it doesn't work, please send me one file with sidecar?
Here's both the image and the sidecar (wetransfer.,com):
Files (24.8 MB total)
dogs-vancouver-20150930-9350.cr2
dogs-vancouver-20150930-9350.cr2.xmp
Will be deleted on: 10 July, 2016
Download link:
https://we.tl/L2EBJGZNx1
Thanks
Syv
Post
by xnview » Mon Jul 04, 2016 8:20 am
ok, XnViewMP check for dogs-vancouver-20150930-9350.xmp not dogs-vancouver-20150930-9350.cr2.xmp
I'll modify it...
Post
by XnTriq » Mon Jul 04, 2016 4:00 pm
Thanks for the samples, Syv :wag:
Yes, I think so. At least, that's how I've set up my installation.
When I change the filenames according to Pierre's advice, …
dogs-vancouver-20150930-9350 .cr2 .xmp
… things work as expected.
Continued discussion:
Sidecar filename
elfroggio
Post
by elfroggio » Tue Jul 05, 2016 2:50 pm
xnview wrote: ok, XnViewMP check for dogs-vancouver-20150930-9350.xmp not dogs-vancouver-20150930-9350.cr2.xmp
I'll modify it...
Wonderfull
Thank you
Justin
Posts: 5 Joined: Thu Sep 22, 2016 6:31 am
Post
by Justin » Thu Sep 22, 2016 6:48 am
Is it possible for the user to choose whether they need the xmp saved as either 'filename.ext.xmp' or 'filename.xmp'. As it stands, the xmp's are not compatible with Darktable and I can find no settings for either choice in both Darktable and XnViewMP.
Thanks.
Posts: 8704 Joined: Sun Oct 12, 2003 6:47 pm
Post
by helmut » Fri Sep 23, 2016 9:27 am
See also discussion/question in topic
Naming of Sidecar files .
