Hello:
I do not know if my problem is because I have both Xnview and XnviewMP installed. and I have had no problems adding text in Xnview before (when I had *only* Xnview installed).
Now, in Xnview, I click Tools > Add text, add the text, set the font, and click OK. Nothing!!!
What might be wrong?
Thanks/Hans L
Add text
Mixer
- Banned
Re: Add text
Did you mean you click Tools->Add text in XnView MP? In XnView (Classic) you have to click Image->Add text, and it works fine.
Hans L
Re: Add text
Sorry, I meant Image > Add text in Xnview (there is no Add text in XnviewMP, unfortunately).
And it does not work for me in Xnview.
Regards/Hans L
Regards/Hans L
- Forum Librarian
Re: Add text
What happens if you press Shift+T in view mode?
Re: Add text
No problem for me using the menu or the above keyboard shortcut, XnView Classic 2.36 x32 ZIP on Windows 7 SP1 x64.XnTriq wrote:What happens if you press Shift+T in view mode?
Could it be that the selected font size is too small in relation to the pixel dimensions of the image, I suspect that could be the problem, or possibly that the selected text colour doesn't display clearly?
When you click on OK do you see the white pointer indicating where the text will be placed?
Hans L
Re: Add text
When I click Shit+T, I get the bos that I get when I click "Add text" in the menu.XnTriq wrote:What happens if you press Shift+T in view mode?
Hans L
Re: Add text
Yes, there is something white after I clicked OK and move the cursor to where I want to put the text. I have set font to Ariel 20 p, and color Red, but still, nothing. I will try again.cday wrote:No problem for me using the menu or the above keyboard shortcut, XnView Classic 2.36 x32 ZIP on Windows 7 SP1 x64.XnTriq wrote:What happens if you press Shift+T in view mode?
