Show files in subfolders / separator for new folder?
Lupin III.
Post by Lupin III. »
I'm using the option "show files in subfolders" in the browser quite often when searching for or sorting pictures. Is it possible to show a separator in the thumbnail list whenever a new folder "starts"? I generally store images in folders by date and I also add a short keyword as description of the occasion to the foldername. Currently I have to go into the file properties of an image to see which folder it is in (and for most paths I even have to scroll the directory entry in the properties by highlighting it to see the actual folder it is in).
Lupin III.
Re: Show files in subfolders / separator for new folder?
XnTriq wrote:You mean a “flat view” with “grouping”, Lupin III?
I guess that is what I mean.
This is how it looks now (images of the same color are in the same subfolder):
and has messy results like this for sorting depending on filenames (order by name should sort by full path name, not just filename):
Instead I'd find it very helpful if it looked like this:
Thanks for the screenshots/mock-ups! I, for one, would certainly use this feature all the time.
