.eps files and Ghostscript: Ghostscript is not found
Hans L
Post by Hans L »
When I double-click on an .eps file, I get this error message:
"Ghostscript is not found on your system, please download it on http://www.ghostscript.com.
Thing is, I have Ghostscript installed on my system.
This is what I have in the registry:
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.eps
OpenWithList
Value Name/Value Data
a/uedit64.exe (UltraEdit)
b/xnview.exe (Xnview)
c/dopus.exe (Dopus)
MRUList/bca
UserChoice
ProgID/Xnview.Image
What might be wrong?
Thanks/Hans L
Re: .eps files and ghostscript
Which version of Ghostscript is installed on your system, Hans L?
cday ([url=http://newsgroup.xnview.com/viewtopic.php?p=126130#p126130]pdfs not displaying in my windows 8.1 laptop[/url]) wrote:Ghostscript x32 for XnView 'Classic' as it is 32-bit software, x64 for 64-bit programs...
You can install both Ghostscript x32 and x64 if you wish.
Hans L
Post by Hans L »
I have gs 9.19 installed (2016-03-23).
Should I uninstall and reinstall? I'll check if there is a later version, but i do not think so). Edit: GNU Affero General Public License, 64-bit
Xnview was installed after gs.
Hans L
Please try installing the 32-bit version of Ghostscript v9.19 in addition to the already installed 64-bit version.
Hans L
Post by Hans L »
Will do.
Hans L
Hans L
Post by Hans L »
That was it. Solved. GS 32-bit is what Xnview wants ... and got :-)
Thanks you!
Hans L
