How to open image with Photoshop, when I click the photoshop icon in toolbar.
After I add --COMMAND-- for Photoshop to the toolbar, I cannot open an image for it to be displayed in Photoshop when I click the photoshop icon in toolbar.
Thank you.
Open jpg with Photoshop, when I click the toolbar icon
Waiman
- Forum Librarian
Re: Open jpg with Photoshop, when I click the toolbar icon
Welcome to the forum, Waiman (-:
Did you add the button to the toolbar of Browse or View mode?
Two related bugs (#843 + #894) have been fixed in v0.80 and v0.82 beta 3, respectively.
Waiman
I have added the icon to both the Browse mode and View mode. In the browser mode, I select an image and click the Photoshop icon. Photoshop will open normally, but the image I selected does not open within the Photoshop. In the view mode, when I click the Photoshop icon, nothing opens, not even Photoshop. I found v0.82 beta 3 have the same problem.XnTriq wrote:Welcome to the forum, Waiman (-:
I also found no matter how many images I select and press the export iconclick the export icon, only one image will be exported.
Thank you.
- Forum Librarian
It seems that the filepath(s) is/are not passed on properly to Photoshop.
Could you please create a batch file…
… and add a button for photoshop.bat to the toolbar for browse mode? (Of course you would have to adjust the command to match your installation of PS.)
"C:\Program Files\Adobe\Adobe Photoshop CS4 (64 Bit)\Photoshop.exe" %*-
Waiman
Still have the same, after I add a button for photoshop.bat to toolbar.XnTriq wrote:It seems that the filepath(s) is/are not passed on properly to Photoshop.
… and add a button for photoshop.bat to the toolbar for browse mode? (Of course you would have to adjust the command to match your installation of PS.)Code: Select all
- Forum Librarian
Thanks for checking!
Are you able to launch Photoshop with Alt+{n} after adding it to the list of programs in Tools » Open with?
More Photoshop-related weirdness:
Waiman
Tools - Open with - Photoshop CS6, or Alt+1 is working.XnTriq wrote:Thanks for checking!
- Forum Librarian
OK, so I'm moving this topic to “Bug Reports” for Pierre (developer of XnView) to take a look at the problem.
Waiman
Thank you.XnTriq wrote:OK, so I'm moving this topic to “Bug Reports” for Pierre (developer of XnView) to take a look at the problem.
