No update setting?
Octopuss
No update setting?
Post by Octopuss »
I was annoyed by update popup every single time I ran the program, so I somehow (no idea how anymore) disabled it, and now I can't find any relevant settings to change it. Help!?
Re: No update setting?
Octopuss wrote:I was annoyed by update popup every single time I ran the program, so I somehow (no idea how anymore) disabled it, and now I can't find any relevant settings to change it. Help!?
Tools > Settings... > Integration > Integration tab -- Check for program updates :D
Octopuss
Post by Octopuss »
Integration! That makes no sense!
JMM72
Post by JMM72 »
I agree the location is counter-intuitive, it should be in general, next to 'only one program instance' imho. The other day I had a popup for 0.83 (false alarm for what it seems) and took me a while to find the setting because I wanted to trigger the update popup again.
Btw, today I also had a popup for update to 0.83, but the changelog shown is for 0.81 and the only download is also 0.81. Are these false alarms or am I missing something?
JMM72 wrote:Btw, today I also had a popup for update to 0.83, but the changelog shown is for 0.81 and the only download is also 0.81. Are these false alarms or am I missing something?
The latest release is v0.81.
[color=green]http://www.xnview.com/update.txt[/color] wrote:
[XnView]
version=2.36
[XnView Deluxe]
version=2.5-1.75
[XnViewMP]
version=0.81
[XnConvert]
version=1.73
Version 0.82 is currently undergoing beta testing.
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=133112#p133112]Version 0.82 or 0.83???[/url]) wrote:it's an error of the first build. The version is 0.82 not 0.83
JMM72 wrote:I agree the location is counter-intuitive, it should be in general, next to 'only one program instance' imho. The other day I had a popup for 0.83 (false alarm for what it seems) and took me a while to find the setting because I wanted to trigger the update popup again.
right general is better
which version do you use?
