Request: Custom Display EXIF In Info Window
Katamara
Post by Katamara »
Hello.
There are a dizzying number of EXIF/ExifTool fields in the Info window.
I would like to customize which Exif fields will display.
For example, only display the below fields...
Date/Time Original= 2016:07:19 18:16:59
MIME Type= image/x-sony-arw
Camera Model Name= ILCE-6000
Exposure Time= 1/1000
ISO= 400
Flash= Off, Did not fire
Lens Info= 55-210mm f/4.5-6.3
High ISO Noise Reduction= Off
Flash Exposure Compensation= -1
Camera Orientation= Horizontal (normal)
Thank you.
Re: Request: Custom Display EXIF In Info Window
This feature is currently being discussed @ “Custom Fields in Info panel”. Do you want me to merge both requests?
