Bold face text in full screen?
photoken
Post by photoken »
Using Win10 Pro x64 and XnViewMP 0.81 x64
I have the following image information displayed when viewing an image in full screen:
\{Folder name}
{Filename}
{File Type}
{Width}w x {Height}h
{Size KB} Kb
{Zoom}%
I'd like to have that {Filename} line displayed in bold type. How can I do that?
Ken
Yes, I think it can be eeeeeasily done...
Just take everything out on Highway 61.
Re: Bold face text in full screen?
Hi Ken =)
MP supports a subset of HTML:
<b>{Filename}</b>
photoken
Post by photoken »
XnTriq wrote:Hi Ken =)
<b>{Filename}</b>
Thanks for the reply, but that does not work -- although those HTML tags work for the information displayed in the tooltip for the browser window, those tags do not work for the information displayed when viewing an image in full screen.
Ken
photoken wrote:Thanks for the reply, but that does not work -- although those HTML tags work for the information displayed in the tooltip for the browser window, those tags do not work for the information displayed when viewing an image in full screen.
Maybe I misunderstood. Aren't we talking about Information displayed in Tools » Settings... » View » Info?
\{Folder name}
<b>{Filename}</b>
{File Type}
{Size KB} Kb
{Zoom}%
photoken
Post by photoken »
Yes. Tools...Settings...View...Info.
The HTML tags for bold do not display the tagged line in bold when the image is viewed in full screen.
Ken
And which font do you use?
Windows XP SP3 | XnViewMP v0.81 | MS Shell Dlg 2
photoken
Post by photoken »
XnTriq wrote:And which font do you use?
Aha! Thanks for showing the font you used.
I always like using SegoeUI Demibold as my screen font, and the bold tags did not affect that font. Changing the font to SegoeUI makes things work as expected:
full screen info.png (16.79 KiB) Viewed 1072 times
As a side note, I tested the bold tags with Arial before posting my original message, but the difference was so slight that I completely missed it. My mistake.... :(
Thanks again for your replies!
Ken
Thanks for reporting back, Ken :-D
