Crash within 5 minutes after installing
dandv
Post by dandv »
I've just installed the latest 64-bit DEB, and wanted to remove the GPS information from one JPG.
Loaded the image, went to File -> Format settings -> Write -> JPEG, unchecked "Keep EXIF", saved as. The image was in a folder with less than 50 files.
XNView MP didn't show the new image, then its window went dark grey, and it crashed with:
XnView crashed with SIGSEGV in QtSharedPointer::ExternalRefCountData::getAndRef()
Tried to upload the log but it's 27MB zipped and the forum rejected it.
Re: Crash within 5 minutes after installing
and you are able to reproduce?
