0.81 - limit tabs in settings broken
harumscarum
Post by harumscarum »
I have limited tab views =1 but in fact it is unlimited
Re: 0.81 - limit tabs in settings broken
I'm unable to reproduce, harumscarum. Do you refer to the Maximum of view tabs option in Tools » Settings… » Interface » Tabs?
harumscarum
yes
each time when I open the image from File Explorer it appears in new tab
:-? I never ran into this issue myself, …
Karl02 ([url=http://newsgroup.xnview.com/viewtopic.php?p=126451#p126451]Simplified Tab Handling[/url]) wrote:- http://newsgroup.xnview.com/viewtopic.php?f=82&t=31328 .72MP How to use as single image viewer?
- http://newsgroup.xnview.com/viewtopic.php?f=82&t=30310 MP 0.68, only ONE tab open please?
- http://newsgroup.xnview.com/viewtopic.php?f=35&t=29980 Is it possible to NOT use tabs?
- http://newsgroup.xnview.com/viewtopic.php?f=35&t=29598 Can somebody tell me how to get the browser tab to open?
- http://newsgroup.xnview.com/viewtopic.php?f=60&t=25848 Behaviour of opening tabs
- http://newsgroup.xnview.com/viewtopic.php?f=60&t=21039 Request: The <no file> tab should be dynamic & be used
- http://newsgroup.xnview.com/viewtopic.php?f=74&t=23640 A tickbox setting for being better economical tab opening
- http://newsgroup.xnview.com/viewtopic.php?f=60&t=23100 Maximum viewer tabs allowed opened
… but maybe following these steps will fix it for you:
badcrc ([url=http://newsgroup.xnview.com/viewtopic.php?p=133263#p133263]Only one file in instance[/url]) wrote:I had the same problem as you and it was driving me nuts.
1) Go to Settings->General
2) CHECK (Enable) "Confirm Session Saving"
3) Exit program
4) Xnview prompts to save session
5) CHECK (Enable) "Do not show this message again"
6) Select "No" button
Now it saved the options to not save session and not to prompt you to save session. When you re-open Xnview it should only open with the image you opened from Explorer. You might have to close open tabs first, I don't remember. To change to saving sessions again or to enable save session prompt you have to follow steps 1-4 again.
harumscarum
worket for me as well - thanks
harumscarum wrote:worket for me as well - thanks
The previous session was restored??
