Doubleclick on thumb for video file does nothing
klaus2
Post by klaus2 »
Windows 7 x64, XnViewMP 081, 0.82 beta3:
Doubeclicking on a thumb for a video file (flv, mp4) does nothing,
where the following doubleclick option is defined: browser <> viewer.
I would have expected that the file is "Open"ed at least.
With browser <> fullscreen the latter is working (file is played in full screen).
Re: Doubleclick on thumb for video file does nothing
Thanks for confirming that this bug hasn't been fixed in the beta of v0.82.
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=133135#p133135]Playing Video clips - When required[/url]) wrote:
bucky ([url=http://newsgroup.xnview.com/viewtopic.php?p=125656#p125656]Playing Video clips - When required[/url]) wrote:1. Press ENTER or double click on video file - does not open in Viewer mode. The video only plays in the Preview panel (ENTER or double click on an image does open in Viewer mode)
This issue is still not fixed.
  • XnView MP v0.79 32-bit (default config) @ XP SP3 (no codec packs installed)
  • XnView MP v0.81 64-bit (default config) @ 7 SP1 (no codec packs installed)
I used WMV (C:\WINDOWS\Help\Tours\WindowsMediaPlayer\Video\*.wmv) and AVI (C:\WINDOWS\clock.avi) clips for my tests.
klaus2
Post by klaus2 »
Correction: doubleclick (or Enter) on video thumbs works when having set the option Video Open With associated progarm.
