Background: I'm looking for something to help me organize photos
– Across multiple destinations (local and remote fs)
– From two different computers (macOS and Linux)
XnView MP seems really nice for organizing, tagging and moving.
With default settings, it seems all tagging etc. are stored in the XnView.db in .config/xnviewmp?
To be able to work with the same photos from two different computers (mac laptop+Linux desktop), I should change settings to store tagging etc. in XMP? Or do I need some sync'ing of that database? (I assume not, as paths would look differently.)
How about XMP sidecars? Storing in XMP, but not sidecar just stores the same info inside the image files themselves?
Storing in sidecar keeps tagging etc separate? What's the main pros/cons of each?
If I understand correctly, edits (crop, color adjustments etc.) are saved directly to image (save as for different versions), not inside .xmp or database? (Like some image organizers would store versions separate and leave master image untouched.)
Other things I should keep in mind when organizing library across local and network drives?
(I usually keep stuff locally on my laptop for a while, then move it to the network share to save space. Then it would be cool if I could access and organize the same photos on the network share from both Linux and the macOS laptop.)
