Auto Image Size
Nounverber
Auto Image Size
Post by Nounverber »
Auto image size is always set to "fit image to window, large only". When I change it to "no fit", it resets to the other setting as soon as I go to the next image. So it's pretty much unusable right now.
I'm on windows 10 and using version 2.36. I have used the full installation if that matters.
Re: Auto Image Size
you need to change it in options
Nounverber
Re: Auto Image Size
Oh I see. I think setting it in the view tab should be saved though. It's confusing and I often need to change the fitting logic depending on the type of content; going into the options every time is a bit of a hassle.
But now I want to report another bug. There is the option "fit window to image" which doesn't do what it says. It never fits the window, it does exactly the same as no fit, as far as I can tell. This is true for the shortcut ctrl+T, too. It's supposed to fit the window to the image, but nothing happens.
