How to display GPS image direction ?
Djelmas
Post by Djelmas »
I feel stupid but I was not able to find how to display the GPS image direction in the information data of the picture viewer.
I've found that pressing I key you have the information fields displayed, then I changed them to display Latitude and Longitude via the Options panel, but I didn't find how to set the image direction tag (latitude and longitude are proposed in a pop-up menu, but not image direction).
Of course I've tried some tags randomly : ImgDir, Direction, GPSImageDirection, ... none of them work.
Can anyone help ? Thank you.
Re: How to display GPS image direction ?
could you send me a file with this field?
Djelmas
Post by Djelmas »
See the attached file. When I open it in XnViewerMP, in the EXIF tab of the Propriétés panel, there's a field labelled "Direction img." that has a value of 18.51°
It's this value that I don't know how to display in the informations of the image view.
Thank you very much.
Djelmas
Post by Djelmas »
I'm not sure that the upload on the forum didn't change the properties of the image. In case, let me know how I can send you the original file.
Djelmas
Post by Djelmas »
So, I've made an upload on some site, I think it's better : http://www20.zippyshare.com/v/wgryLXJW/file.html
See Issue 929 for details.
Djelmas
Post by Djelmas »
Thank you very much. That will be an useful information for me (and for others I hope).
I feared at first that I was stupid not to succeed by myself, and I'm glad to see that it was on the software side :)
I'll be waiting (impatiently) for the next version.
