Configurable popup info for videos
Erixx haxx
Post by Erixx haxx »
<Moderator's note: Originally this was a bug report but it turned out to be a suggestion.>
____
Subject: Video: Popup Info Wrong
Hello:
The popup info for the thumbs "On Hover' is wrong.
Example: If I insert this <b>{Filename}</b>
Then I get File Name + ext. Instead of just the file name. Just on video
Thanks
win7x64pro
Re: Video: Popup Info Wrong
:bugconfirmed: Mismatch in tooltip variables
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=94291#p94291]Filename descriptions mismatched[/url]) wrote:I'm glad you brought this issue up, marsh.
XnView v1.9
  • Tools » Options... » Browser » Browser » Show tooltips
    • Filename with extension ~ <Filename With Ext>
      Filename ~ <Filename>
    Tools » Options... » Browser » Thumbnails » Thumbnail Label
    • Filename
      Filename (without extension)
XnView^MP v0.35 beta
  • Tools » Settings... » Browser » Browser » Use tooltips
    • Filename ~ {Filename With Ext}
      Filename without extension ~ {Filename}
    Tools » Settings... » Browser » Thumbail » Labels
    • Filename
We need a unified nomenclature in XnView, XnView^MP, and XnConvert for...
  • Browser labels
  • Browser tooltips
  • Title bar info
  • Fullscreen info
  • Contact sheet info
  • Web page info
klaus2
Post by klaus2 »
... or some info is not shown completely (video files), example: the file size
where the layout for the tooltip has been defined as:
<b>{Filename}</b><br>{Modified Date} - {Date taken}<br>{Size KB} Kib
File size is not shown at all (empty)
Currently popup info can't be configured
Erixx haxx
xnview wrote:Currently popup info can't be configured
Ok, I understand. I guess I need this under Suggestions Instead.
Sorry...
* Feel free to move this Xntriq or mods *
Thanks
