[Fixed] 0.81: VideoMode Set True Bug
Erixx haxx
Post by Erixx haxx »
Hello
When VideoMode is set:
VideoMode=true
Effect is:
-When switching into fullscreen MP opens in Windowed mode.
-Also the switching mode gets corrupt. ex. you can't double click out.
-escape button has to be pressed twice
win7x64 pro
MP0.81x64
Re: 0.81: VideoMode Set True Bug
See Issue 1037 for details.
This problem is supposed to be fixed in XnView MP 0.84 beta 3. Could you please try and confirm the bug fix, Erixx haxx?
Erixx haxx
Re: [Fixed] 0.81: VideoMode Set True Bug
Seems to work with brief test so I'll go ahead and mark it as such.
Bug 0000931 is the same bug as Issue 1037.
In the bug tracker. I think 0931 was the original. It was entered a day or 2 after my OP. So it can probably be marked off in the bug tracer also.
EDIT:
It also links back to this thread, so it was the original.
Anyways
Thanks greatly for the fix. Helps alot
