Find Similar Files - Restrict to 100%
chrisrash
Post by chrisrash »
I'm using the Find Similar Files function to identify render errors in a DPX sequence out of Resolve. The render errors are a frame that shows the offline media indicator, so it would be great if XnView would show only images with 100% similarity.
I had been setting the tolerance to 100 in the Find Similar menu, so all similar images would be grouped together, but that's the extent of it. I still had to scroll through the shot groupings for the entire reel before I could find the group of render errors.
Is there any way for me to limit the application to show only images with exact duplicates? That would leave me with frames of black, leader, duplicate frames due to time remaps and these frame errors.
Re: Find Similar Files - Restrict to 100%
if you use a 100% similarity, you'll have only these files....
